Please let me know if each concurrent client connection in NF with SQL option needs separately SQL client license. Jakub Nowakowski jakubnow@optimus.poznan.pl
Hello Jakub You need to have a SQL client license for each concurrent user in NF with SQL option, because you have to log on to the SQL server to get access to the database. So if you have 30 NF licenses and only 20 SQL lincenses, only 20 will be able to access your database at one time and the remaining 10 can only be used if you have per server licensing on your SQL-server. Hope this helps. Thomas Ravn-Jensen Aston Naviteam Business Intelligence
