how I can the date of days after ?
hi
I have to known how I can known the next days for exemple :
i have the delivery date in AX every one day of week exemple : the employee select new york every monday I do the delivery of product ; but ht developper don’t known what the employee select he must comper the day of today with the date of delivery in new york but if i have an order in tuesday the next delivery is in the next monday
how I can have the date of the next delivery dynamicly ?
thank you
Hello Hakim,
You can use dates in additions and subtractions when you are using the date as the principal type; that is, if you are subtracting from or adding to a date, like this:
date = date - integer or date = date + integer
Dates are not automatically converted into other types, but you can use integer values in the computation of dates. For example:
void myMethod()
int anInteger;
date aDate;
// Sets the date variable adate to January 1, 1998
aDate = 1\1\1998;
// Sets the integer variable anInteger to 30.
anInteger = 30;
// Sets aDate to aDate + 30; that is the 31st of January 1998
aDate = aDate + anInteger;
print aDate;
pause;
The date printed will be 31\1\1998.
So to compute the delieverydate you’ll have to use the following expression:
delieverydate = orderdate + 6;
I known that thank you but supose that I don’t known the day where I want compare my delivery exemple
today is 15/08/2011 and the day that i want to compare is sunday but so the delivery is in the next sunday ok
but for me the day of comparison is unknown to me, I even make a code to detect the days on which I need to compare and add value at the date today dynamicly?
thank you
hi
this is what I want :
plan plan;
int k,j1,j2,j3,td;
int adddate;
str today;
k = 0;
while select hal_days from plan where plan.hal_sect == sect1
day = enum2int(plan.hal_days);
if (k == 0)
j1=day;
else{
if(k == 1 )
j2 = day;
else{
j3 = day;
k++;
td = (dayofwk(systemdateget()));
theday= dayname(td);
adddate = 0;
if ((td == j1) || (td == j2) || (td == j3))
td++;
adddate++;
while ((td != j1) && (td != j2) && (td != j3))
adddate++;
if ( td == 7 )
td = 1;
else{
td++;
dj = systemdateget() + adddate;
ttsbegin;
select forupdate salesTable where salestable.SalesId == sid;
salestable.hal_dateliv=dj;
salestable.update();
ttscommit;
