How get delivery reminder in Excel sheet in ax 2012r3 ?
Hi Experts ,
How we will get the delivery reminder field value in Excel sheet in ax 2012r3
I am creating sales order useing sales quotation .
I have one field called balance against PPAP Qty :
Path for delivery reminder field :-so lines >> Updatelines >>delivery Remainder field .
private void run()
CommaIo io;
Dialog dialog;
DialogField dlgFileName;
Filename csvfileName;
FileIOPermission permission;
int recordCount = 0;
int i=0;
String20 quotaionJourId;
int strLength;
AccountNum accountNum;
SalesTaker pesron;
int j;
utcDateTime Crddate;
SysOperationProgress exportprogress = new SysOperationProgress();
#File
#AviFiles
try
exportprogress.setCaption(“Exporting quotation lines to CSV file…”);
exportprogress.setAnimation(#AviTransfer);
// Header Column
conHeader = [“CUSTOMER NAME”,“PART NO”,“PART DETAILS”,“PRICE”,“QUOTATION NO”,“CARD ISSUED DATE”,“CRD DATE” ," crd date", “PPAP QTY”,“TOTAL PPAP VALUE”,“DISPATCH QTY”,“DISPATCH VALUE”,“BALANCE AGAINST PPAP QTY”,“DISPATCH QTY per DATE”,“Remarks”];
dialog = new Dialog(“Exporting quotation lines”);
dialog.filenameLookupFilter([“Excel Files”,"*.csv"]);
dlgFileName = dialog.addField(extendedTypeStr(FilePath),“File Path”);
queryRun = new QueryRun(queryStr(PC_PPAPCard));
if(dialog.run())
csvfileName = strFmt(@"%1%2%3_%4.csv",dlgFileName.value(), “PPAP Details”, date2str(today(),321,2,0,2,0,4),strRem(time2Str(timeNow(), TimeSeparator::Colon, TimeFormat::Hour24), “:”));
if(csvfileName)
permission = new FileIOPermission(csvfileName,#io_write);
permission.assert();
io = new CommaIo(csvfileName,#io_write);
io.inFieldDelimiter(’,’);
if(!io || io.status() != IO_Status::Ok)
throw error(“Error in opening file!”);
io.writeExp(conHeader);
if(queryRun.prompt())
while( queryRun.next())
custQuotationJour = queryRun.get(tableNum(CustQuotationJour));
custQuotationTrans = queryRun.get(tableNum(CustQuotationTrans));
inventtable = queryRun.get(tableNum(InventTable));
salesQuotationLine = queryRun.get(tableNum(SalesQuotationLine));
salesQuotationTable = queryRun.get(tableNum(salesQuotationTable));
custTable = CustTable::find(custQuotationJour.InvoiceAccount);
inventTable = InventTable::find(custQuotationTrans.ItemId);
select ExternalItemID from custVendExternalItem
where custVendExternalItem.CustVendRelation == custQuotationJour.OrderAccount
&& custVendExternalItem.ModuleType == 4
&& custVendExternalItem.ItemId == inventTable.ItemId;
select InvoiceAmount from CustInvoiceJour
where CustInvoiceJour.SalesId == CustQuotationJour.SalesId;
if (custQuotationJour.PC_QuotationStage == PC_ItemStage::PPAP)
conQuotationData = [ custQuotationJour.OrderAccount,// 1 customer Name
custVendExternalItem.ExternalItemId,// 2 part no
inventTable.itemName(),// 3 part name
custQuotationTrans.SalesPrice,// 4 price
custQuotationTrans.quotationDocNum(),//5 quotation number
custQuotationJour.QuotationDate,// 6 card issue date
salesQuotationTable.createdDateTime,//7 CRD DATE
custQuotationTrans.Qty,// 8 PPAP Qty
CustQuotationTrans.lineAmountInclTax(), // 9 Total PPAP Value
CustInvoiceJour.InvoiceAmount,// 11 dispatch value
salesquotationline.PC_SpecialRemarks// 14 remarks
io.writeExp(conQuotationData);
CodeAccessPermission::revertAssert();
info(strFmt(“Report generated and saved. Path: %1”, csvfileName));
else
info(“Invalid file name specified!”);
catch(Exception::Error)
throw error(“Erorr in exporting journal lines.”);
Please suggest me …
You can get the salesLine from CustQuotationTrans by using Tables\CustQuotationTrans\Methods\salesLine
After having the salesLine, then it would be \Data Dictionary\Tables\SalesLine\Fields\RemainInventPhysical (or) \Data Dictionary\Tables\SalesLine\Fields\RemainSalesPhysical depending on Your requirement
RemainInventPhysical - is delivery reminder in inventory unit.
RemainSalesPhysical - is delivery reminder in sales unit.
HI Kranthi, stil i am unable to get the “Remainsalesphysical” value in the excel.
I really thankful if give me the code .
select * from custInvoiceTrans
where custInvoiceTrans.InventTransId == CustQuotationTrans.InventTransId
join custInvoiceTrans where custInvoiceTrans.SalesId == salesTable.SalesId
&& custInvoiceTrans.ItemId == SalesLine.ItemId;
// for Remain sales physical
select sum(RemainSalesPhysical) from SalesLine
where SalesLine.ItemId == salesQuotationLine.ItemId
join salesTable where salesTable.QuotationId == salesQuotationLine.QuotationId
&& salesTable.SalesId == SalesLine.SalesId;
conQuotationData = [ CustTable::find(custQuotationJour.OrderAccount).name(),// 1 customer Name
custVendExternalItem.ExternalItemTxt,// 3 part Name
// inventTable.itemName(),// 3 part name
//salesQuotationTable.createdDateTime,//7 CRD DATE
DateTimeUtil::date(DateTimeUtil::applyTimeZoneOffset(Crddate,
DateTimeUtil::getUserPreferredTimeZone())),
custQuotationTrans.lineAmountInclTax(), // 9 Total PPAP Value
custInvoiceTrans.Qty,// 10 dispatch qty
custInvoiceTrans.lineAmountInclTax(),// 11 dispatch value
salesLine.RemainSalesPhysical,//12 BALANCE AGAINST PPAP QTY
salesline.PriceUnit * salesline.RemainSalesPhysical,//BALANCE AGAINST PPAP VALUE
custQuotationTrans.PwC_SpecialRemarks// 14 remarks
It seems you are exporting data for every custQuotationTrans record. If so, you can use the below code
salesLine = custQuotationTrans.salesLine();
