Hello,
This may sound obvious but I have actually never been in the scenario to learn this. I have a temporary table populated and I want to traverse it. I have tried the following:
while select tmpTable
// do something
Yet that doesn’t seem to do it…
Any answers or ideas will certainly be appreciated!
Actually, I believe the issue is more complicated because the temporary table is packed in the parent class which is passed from another form. I can’t seem to find any information regarding packing of temporary tables except for the following “Pack-Unpack Design Pattern” located in http://msdn.microsoft.com/en-us/library/aa879675.aspx. It just mentions it is possible to pack temporary tables. I simply provided it in the #localmacro.CurrentList section in my Class’s classDeclaration and pass it as a parameter from the caller form.
The weird thing is if I set a break point on the while, it shows there is a record in the buffer yet the while statement is never executed. I tried to also print the number of records but I actually get a 0 record count using the following:
void tmpCount()
TmpTable tmpTableCount;
int64 recordCount;
tmpTableCount.setTmpData(tmpTable);
select count(RecId) from tmpTableCount;
recordCount = tmpTableCount.RecId;
info(strfmt(“Total tmpTableCount records = ‘%1’”, recordCount));
Not sure if this helps or makes things more confusing!
