I want to print item number in barcode format by barcode printer. I have tried to use barcode font in naivision report. Unfortunately, I didn’t work. I still got the item number on the report. What should i do? Please recommend.[V]
You can find some font where all is good I use that, but I can’t reminder where I find this font
What are you specifying in FontName property? 1 - FileName of the font (as it appears in Control panel) 2 - Font Name (as it appears when you use it in excel, word, …) I tested both and it works with option 2. Hope it helps. Jesús Soage
