How do I calculate sub total in MS Dynamics NAV?
Hello
I have to calculate total os the follwing calculated field.
=Fields!TempAppliedCustLedgEntry__Amount_to_Apply_.Value * DateDiff(“d”, Fields!TempAppliedCustLedgEntry__Posting_Date_.Value, Fields!Cust__Ledger_Entry__Posting_Date_.Value)
Thank you
Barathy
This is not Navision code! Where are you creating this code?
This looks like sql reporting services. You need to add a group footer/header and add the field as text.
Thank you Rashed Amini. I modify my reports using Visual Web Developer.
