How do i add image to excel with x++
i want to add image to excel with x++ ax 2009. how do i do this?
already discussed before , please check below link
dynamicsuser.net/…/16803
Thanks Kunal,
I examined the link. Creating a new Excel document. But I have to open a document that you want to insert a picture into it. Can you help with this?
comApplication.visible(true)
try if it is working or not
at the end of the code
instead of
//Force app to quit
comWorkBook.saveas(“c:\temp\hello.xls”);
comWorkBooks.close();
comApplication.quit();
you can try
//Force app to quit
comApplication.visible(true);
Hi again Kunal;
I have an xls files as templates . I 'm trying to add an image to determine a location into the open this file . Xls file in this example creates a new form. I want to use the saved XLS file in the existing template . You can open and save data into the existing xls file using the following method . But I can not add photos …
SysExcelApplication application;
SysExcelWorkBooks workbooks;
SysExcelWorkBook workbook;
SysExcelWorksheets worksheets;
sysExcelWorksheet worksheet;
SysExcelCells cells;
SysExcelCell cell;
application = SysExcelApplication::construct();
workbooks = application.workbooks();
workbooks.open(“c:\test\template.xls”);
