i have two forms like accountability and approval form.while iam entering the data into accountability form when i click submit function it will goes to the approval form…but i have 3 field ref no,quater,and description…these fields does not existing data.
i set the table relation for the forms even though the values are not getting…plz give me reply
Different tables like accountability has general line table and approval has approval line table…but some common fields is present inthat form…some fields like line no,document no,amount values are inserting while clicking submit into accountbaility form…Remaining rf no,ref decsription,quater does not have values.
in the function button i can use this transfer code??
ya the 2 fields has same id in the two tables…i added one field in the approval line table so can i add in the field in the gen.journal table.where can i write the codein that field validate trigger??
it has one codeunit like workflowmanagement in that insertapprovingline function is there in that fileds are assigning .when we r submitting it will go to linedistribution buffer.
hi mohana i added the field in codeunit…2 fields are flowing into other form…one field was not flowing…that field is option field…i added this field in temporary table…how i can write code for option string??
…i wrote for the two fields like this
TempLineDistBuffer.“Receipt Ref. No.” := GenJnlLine.“Receipt Ref. No.”;
TempLineDistBuffer.“Receipt Description” := GenJnlLine.“Receipt Description”;
TempLineDistBuffer.Quater := GenJnlLine.Quater;//this one was not gng to another form…plz suggest me
