I want to use Post Event handler for few fields. But field id and Table buffer are not coming together in AX 2012 R2.
if i am using “XppPrePostArgs _args” then system is not allowing to take "FieldId _fieldId, TableId _tableId ".
Which method are you trying to extend? Does it accept exactly two parameters, FieldId and TableId? If not, that’s the reason. If it has, can you please provide more details about your problem? For example, the error message you get?
