i am using Navision 2009
Add integer field (ItemInt) in Item tables.
Modify the Item List Page, which use as a web service.
In C# web service i assign the value of int varaiable and pass to Item card.
ItemInt = 145 ;
when i create or update the ItemInt filed, its not set the value 145 of ItemInt Variable in Navision.
All othe fields are created or updated successfully.
How can i use integer fields in Navsion to Create and update data using web service.
