What config enables a hyper link for Journal Workflow notification email.
When you are generating the email template (depending on the workflow either under System email templates or Organization email templates) - you can use the P drop down to insert specific information.
You can link directly to the workflow alert or the item that needs approved.
When I was setting my templates up during testing, I entered all fields with the selection so I could see what would be populated and use that to make my selections.
There are also placeholders within the workflow setup (Insert Placeholder) that can include specific information about that workflow instance.
