hi everybody,
i created a new form with three fields…when iam clicking in the no field tha other fields data should come…can u suggest me
hi everybody,
Pressi, you again started to ask question without explaining what did you try…
i M NOT GETTING ANY IDEA TO GENERATE THATS WAY IAM ASKING
There are somany examples in Navision.
Did you check how customer/vendor details are added to sales header /purchase Header when Customer/Vendor No. is selected?
Did you check how Item details are added to sales Line/Purchanse Line when Item No. is selected?
Dear,
You need to read the Navision Technical manual very carefully ,need to understand the concept of functions,triggers.
As well as You need to look at How standard programming is done. How they use every function .
Always Press F1.
ok amol.but it was little bit confusion…can u provide me any links are there to read navision clearly
MSDN is best way to read all the functionality of Navision…
ok thank u to both of u…
