how can i clear the form bounded field values in dialog form
When i open the dialog form which is having fields of bounded, the problem is every time when i open that form it brings the last record value . i just want to clear all fields when i open that form
For what purpose the dialog has been created? If you are trying to create a new record with that, you need create a new record while opening the form, so it wont show the last record from that table.
Have a look at \Forms\PurchCreateOrder
Thanks for ur suggestion … i changed those fields into unbound then its worked .
have a look on below link for clear the form bounded fileds values while form loading,
dynamicsuser.net/…/clear-text-box-when-i-open-form
