kojiro
1
Dear all,
I want to automate below process.
I have never done any automation in NAV. I think I should use job scheduler for this automation.
Could anyone tell the possibility and how I can make it?
Process :
Export Sales Inquiry report (excel file) from NAV and save the excel file to a selected folder.
Best regards,
KAZ
Go to form in navigation pane
administration>>application Setup>>job queue>> JobQueue entries…
here you can schedule the event.
to define the path, specify it in the report and ask to save as using this code
XlWrkbk.SaveAs(Path+filename.xls);
kojiro
3
Thanks a lot Melvin!!
Since I cannot access to NAV right now, I will follow your advice and reply you again.
KAZ
Hi Kaz.
If you’re looking to automate you tasks to eliminate the repetition, be sure to also consider automation tools. I recommend Automation Anywhere.
Easy to use and not expensive. There’s a free trial version here: www.automationanywhere.com/erp?ptr=tvl
Hope this helps.
Tom
kojiro
5
Hi, Melvin
One mistake, Sales Inquiry is not REPORT, it was a FORM.
Could you tell me how to set it up again?
Best regards,
KAZ
kojiro
6
HI, Tom
Thanks for your suggestion.
I will check it out.
KAZ
Hi KAZ:
Have you tried downloading the trial version yet? Let me know if you have any questions or feedback. I like to collect user experiences.
-Tom
