I have two fields. Say Field1 and Field2.
Field1 having data like A, B, C, D, E
Field2 having data as checkbox.
so i want to develop AOT query in which filter should be like this A, B, C, D all should be false and E should be true.
How can I design range node for this query.
If I understood you correctly, then the solution would be:
Just drag your table in AOT query datasource and then expand this datasource node .
Then, drag field2 under Range node and go to field2 under range node. Set Value property to 1.
Now, use this query as a datasource for any form.
If you have other queries, do reply…
Hi
In AOT Expand Query Node as u mention
We have two fields in Fields under Datasource
Now ready to add ranges as for our requirement
when value is 0 … take as …
when value is 1 …
this quey used as datasource for reports or Forms
Hope it will correct or help
