hour to minute
public real HoursToMinutes(real totalHours)
real minute,totalMinutes;
int hour;
hour=any2int(trunc(TotalHours));
// BP Deviation documented
minute=frac(decround(TotalHours,2));
if(minute!=0.00 || minute!=0)
TotalMinutes=(hour60)+(minute100);
else
TotalMinutes=(hour*60);
return TotalMinutes;
That’s nice [:D] anything else you need?
please explain the above code
Sreenu
The method is straight forward. For a given hours, it returns number of minutes.
thanks for reply my dought is here below we are taking minute*100 why should take 100
You should look at the previous lines of code. Specifically the following lines -
In the first line, two standard functions are used - decround and frac. Look up these functions in MSDN.
For example, if the value in minute variable is 0.01, then multiplying minute with 100 will give 1 which is correct.
