Hi all! We are running NA (DE)3.60.A - technically (DB still NF (DE)2.60.D) on a WinNT-Server (AOAPP99), DB-Size is 32GB (16 Files at 2GB). We have a nearly identical Server (AOAPP98) that we use as Backup-System. Now, we want to copy the 16 Files of AOAPP99 to AOAPP98 by using HotCopy: ::Backup.bat @echo off d: cd d:\programme\navision attain\database server\ hotcopy.exe source=abendsicherung.ini pause
; Abendsicherung.ini [Backup Files] f:\database\db-00.fdb=\\AOAPP98-RZ\f\database\ g:\database\db-01.fdb=\\AOAPP98-RZ\g\database\ g:\database\db-02.fdb=\\AOAPP98-RZ\g\database\ g:\database\db-03.fdb=\\AOAPP98-RZ\g\database\ h:\database\db-04.fdb=\\AOAPP98-RZ\h\database\ h:\database\db-05.fdb=\\AOAPP98-RZ\h\database\ i:\database\db-06.fdb=\\AOAPP98-RZ\i\database\ i:\database\db-07.fdb=\\AOAPP98-RZ\i\database\ j:\database\db-08.fdb=\\AOAPP98-RZ\j\database\ j:\database\db-09.fdb=\\AOAPP98-RZ\j\database\ k:\database\db-10.fdb=\\AOAPP98-RZ\k\database\ k:\database\db-11.fdb=\\AOAPP98-RZ\k\database\ l:\database\db-12.fdb=\\AOAPP98-RZ\l\database\ l:\database\db-13.fdb=\\AOAPP98-RZ\l\database\ m:\database\db-14.fdb=\\AOAPP98-RZ\m\database\ m:\database\db-15.fdb=\\AOAPP98-RZ\m\database\ [Options] description="Abendsicherung AOAPP99 nach AOAPP98" dbtest=min cc=no servername=AOAPP99-RZ user=******** password=******** osauthentication=no nettype=tcp
When running Backup.bat, HotCopy ends with an ERROR:
quote:
The operating system can not gain access to the file. Check file type and attributes
[:(!] Well, the file-types are *.FDB, there are no attributes like A,R,S,H; all source and destination directories/files are “completely open”, means that any User has full access to them. We checked the connection like this (Command Shell on AOAPP99):echo Test! > \\AOAPP98-RZ\f\database\test.txt
this works … Also a manual copy of FDB-files from AOAPP99 to AOAPP98 is possible.copy f:\database\db-00.fdb \\AOAPP98-RZ\f\database\
So what’s going wrong? Any ideas? Hints? Thanx in advance, Jörg [B)]
