Hi, I have updated few existing objects during customization. Now when i am trying to upload Hot-Fix the modified objects (by me) are not upgrading. it is replacing the older object. Is there any way i can synchroniz my work with the hot fix. How version would help me? do u know abt any tool by which i can compare the code of two object & make changes accordingly Thank You Soumya
Hi soumyadip, There’s a File comparing utility which allows you to compare two text files line by line, you can use it by exporting the FOB’s in Text format and then comparing ur hotfix with the base version. I donnt know how to upload that utility. u can mail me at ajay_setin@yahoo.com to have the utility. I am not gonna charge u anything…be assured…
