Horizontal Scroll Bar does't appear on AX forms if the form size is set to small.
I am facing a problem regarding the form size. When ever i Open a form in low resolution (800 x 600) most of the the form fields doesn’t appear. the reason is that i have a large form that contains too many fields, Although i have set the Height and Width property of form design to Column Width and Column Height.but no Horizonal scroll bar appear as i change the size of the form manually,
Does any body have the idea how the horizontal Scroll bar automatically appear on the form, whenever i change the size of the form or the form is viewed in a low resolution mode, so that all the fields can be viewed easily by moving the horizontal scroll bar left to right.
Please suggest me the solution as soon as possible.
