Hello All,
I have requirement that I need to create enum with values as ex. 1-10, 11-20, 21-30…
When I created enum, added the value and the properties for value is name and Label .
I have given label as 1-10 but when give the name as 1-10 system not allowing the numbers as a name. Hence given the name as ABC
So when add the field in form and when we select the value for Enum is appearing the label(1-10) value in dropdown.
The problem is when I export the data from DMF the value for enum is exporting as ABC not 1-10.
My requirement is that I need to import value for the same enum and my client can provide the value as 1-10…How Can I achieve this?
Pls suggest
