Hire new worker button disabled
Here is an issue regarding the Human Resourse module. I am going to create a new employee in the Employee master in HR module but after filling all the details like name, Legal entity etc, I found that ‘Hire new worker’ button is disabled.
Any help for sorting the problem out is highly appreciated.
Thanks & Regards,
Parashar Banerjee.
once check the employement start date and end date , end date should greater then start date.
Phani
Hi Phani,
I have given the end date to never but still its not working.
Thanks & Regards,
Parashar Banerjee.
Run the number sequence wizard.
Yep Amad…
It worked after running the No. sequence. Thanks a lot for the help.
Thanks & Regards,
Parashar Banerjee.
Hi Adam,
wht do u mean by running sequence wizard? It’s ruining for me … did u mean i have to create another number sequence through wizards.
Many thanks in advance.
Razan
Organization administration → Number sequence → Generate
Hi Krishna,
Thanks a lot for your prompt reply, Actually i know how to do this scenario but my qstn is how to make the hire new worker Button enabled even if it has it’s own sequence number…
I think the button has NeededPermission set to Create
Make sure that user has permission to do the operation also refer below links.
http://dynamics-ax.blogspot.ae/2011/12/ax-2012-hiding-form-control-without.html
http://dynamicsuser.net/forums/p/76503/422392.aspx
Many thaaaanks for your prompt reply Krishna [:)]
Hi Krishna,
I resolved the issue yesterday by deleting the pending records in Status List for the personnel number number sequence , and also applying the manual clean up in the number sequence form.
But unfortunately the issue returned after a while, i believe it’s not a permission issue, is there anything can i do to fix this issue permanently.
