Hi all, There are some Navision objects (Table 36, 38) which use expresions like IF HideValidationDialog THEN . . . else . . . to ask for a CONFIRM action thru a dialog box. There is also a function on those objects like SetHideValidationDialog(NewHideValidatioDialog : Boolean) HideValidationDialog := New HideValidationDialog; I think I know the way and where use this function but I cannot find any reference in the whole Navision. Any comments about? Thanks, Joaquín
In Nv Webshop, dispacher can not show dialog message with Stock validation, Credit validation etc.
SetHideValidationDialog is a function coded within Table 36 (for example). The variable HideValidationDialog is a Global variable defined in that table and the variable NewHideValidationDialog is a local variable defined in the SetHideValidationDialog function. In other words, all this is local to this table and is not a general Navision C/AL function. Dave Studebaker das@libertyforever.com Liberty Grove Software A Navision Services Partner
