How to hide selected record (row) of grid in ax 2012?
Could you elaborate your requirement a little bit?
can you please explain your query bit more.
You can use filters available for the grid. And also you can use the record level security to hide specific records for particular users.
I have two grids in form with same data source , i am transferring selected records from one grid to another. Now when transferring records from one grid to another i want to hide the selected records of particular grid.
One more thing i want to add for above problem that i’m not using checkbox field in table.
Plz help
You need some indication of what should be displayed in each grid and filter out everything else on datasource level. If you don’t have anything better, you can maintain a collection of IDs in your form and add ranges to datasources to include or exclude records with these IDs.
