Hide Human resources module in Prod environment in AX 2012 R2
I want Hide Human resources module in Prod environment in AX 2012 R2.
I tried by removing license from License Configuration form, but its not work for me.
Please guide.
Prashant
if you disabled the license configuration then it must hide the HR module, you can also do one workaround
in aot goto HRM menu, in the property window set the configuration key which is disable , so that menu will be disabled automaticaly
Hey thanks kunal its work.
Go to system adnministartion->setup->license_.license configuration and note one configuration key which is disabled(unchacked)
Then goto HRM menu, in the property window set the configuration key which is disable
