In reports while creating dialog i have added dimension as dialog field, In that i want to hide two array elements (i.e) purpose and costcentre…
hoe can i achieve it?? pls help me to get out of this issue.
That means u want to show only the department in the dialog
I can suggest u an alternative way…
Create an EDT like - Department
Creats relations for department
Department == dimensions.Num;
0 == Dimensions.DimensionCode ;//(‘0’ is the value for department - which u can see in the SysDimension Enum)
And use this EDT in your dialog…This may help u
where i get the edt values in fetch method.where all values are stored for that department
