Hi everybody:
One question. I setup a boolean on User Setup table to hide/show unit cost. It works but on subforms it only hides unit cost title but no the information. Any idea why?
Thank you in advance
Hi everybody:
Excuse me I forgot something. We bought History & Security Table granule. This granule only hides fields that are on tables. Does someone knows if it works for forms too?
Thank you again[:)]
This is not a granule, its an Add-On.
Basically the addon only hides fields on FORMS, not on the table it self.
When you integrated the objects, you would have added code to your forms that will allow this to happen. If you add your own controls to the forms, then you will need to modify the add on to integrate the field/control into the basic Add-On.
