HIDDEN Forms cannot be displayed
First time I clicked on HIDE for a form, now the form appears in AX in the size of a 1inch length and breadth. I cannot see the menu COMMAND. If i could see that menu then i could click SHOW ALL.
I tried by ALT+F, then C for the command menu. But it did not work.
WARNING: Please don’t try on any important menu as it seems to be a SERIOUS BUG.
regards
TP
Nope it is not a serious bug you simply clicked in the wrong area and hid everything.
You can get this back by removing it from your usage data.
Please tell me how I can remove it from my usage area?
Hi
Tools - Options - Usage Data Button - Form Setup
Locate the form you cannot see and press delete - it brings it back minus your changes.
