I am created Two Tables Like ProductTable and CustTable
in productTable fields are ProductType,ProductCode and ProductName
and CustTable fields are CustNum,CustName, ProductType ,ProductCode and ProductName
in ProductTable Data stored like
ProductType ProducCode ProductName
sofa 1 S1
sofa 2 S2
chair 1 C1
Chair 2 C2
Cot 1 CT1
Cot 2 CT2
so now i have to get data in CustTable
like in ProductType i have to get lookup with sofa,chair,cot
then where i select sofa in ProductType i have to load only s1,s2 in ProductName
Plzzzzzzzzzz
suggest me some code as soon as possible
Thanks in Advance
If possible can any one send code to this mail
sridsr3@gmail.com
Hi Srinivas,
Take a String edit field for look up in the grid and override the lookup method of the Stringedit and in Properties of that control ,add datasource as ProductTable and datafield as " ProductType "…Do it a try and if any error comes,do post again.
aedula
March 6, 2012, 6:06am
#4
hi,
try like this…
first of all create an EDT for product type to fetch the data entered in product table to custtable…
and give that EDT to product type fields in both the tables…
now in order to get the product name based on the product type…
write this code in the product name datasource lookup method…
public void lookup(FormControl _formControl, str _filterStr)
Query query = new Query();
QueryBuildDataSource queryDataSourceCode;
QueryBuildRange queryBuildRange;
SysTableLookup sysTableLookup;
producttable producttable ;
sysTableLookup=SysTableLookup::newParameters(tableNum(producttable ),_formControl);
sysTableLookup.addLookupField(fieldNum(producttable , producttype));
sysTableLookup.addLookupField(fieldNum(producttable , productname));
queryDataSourceCode = query.addDataSource(tableNum(producttable ));
queryDataSourceCode.addRange(fieldNum(producttable , producttype)).value(custtable.producttype);
sysTableLookup.parmQuery(query);
sysTableLookup.performFormLookup();
Dear Chaitanya Kumar
thank you very much for your code
Srinivas
