hi
i need to create a new lookup in form. the requirement is if we select a value in InvoiceAccount field in form corresponding invoiceids should display in the InvoiceId field.
InvoiceAccount field i taken from CustInvoiceJour table and InvoiceId field is i created and i used EDT InvoiceID for that.
public static void LookupInvoiceIdbyCustAccount1(FormControl _callingControl,InvoiceId _invoiceId)
Query query;
QueryBuildDataSource qbds;
QueryBuildRange qbr;
SysTableLookup lookup;
query = new Query();
qbds = query.addDataSource(tablenum(CustInvoiceJour));
qbr = qbds.addRange(fieldnum(CustInvoiceJour,InvoiceId));
qbr.value(queryvalue(_invoiceId));
lookup = SysTableLookup::newParameters(tablenum(CustInvoiceJour), _callingControl, true);
lookup.parmQuery(query);
lookup.addLookupField(fieldnum(CustInvoiceJour,InvoiceId),true);
lookup.addLookupfield(fieldnum(CUstInvoiceJour,InvoiceAccount),true);
lookup.performFormLookup();
and i called this method from form control that is InvoiceId in the form.
cau anyone help me? Thankyou…
First, please think about whether “hi” is an appropriate name of a thread.
Second, can’t you simply add a composite relation to the table?
Last, I don’t see any description of what doesn’t work in your solution.
Nevertheless I noticed that you set returnItem (second parameter in addLookupField()) twice, that’s wrong. And according to your requirement, you should add range to InvoiceAccount, not InvoiceId.
sorry, for time being i wrote like that,
i blocked taht second parameter and i set the range for invoiceId.but still i am not getting the lookup in for InvoiceId field in the form.
i called this method in the form control which is InvoiceId in the datasource, i wrote like this…
public void lookup(FormControl _formControl, str _filterStr)
CustInvoiceJour::LookupInvoiceIdbyCustAccount(_formControl,CustInvoiceJour.InvoiceAccount);
super(_formControl, _filterStr);
can you help me in this recipe?
Thanks…
Apart from that, you should remove the call to super()…
i blocked the super in the above code with comments.
but still i am not getting the lookup in the form for InvoiceId field.
can u plz check it kranti.
It works for me so you just an error somewhere.
martin can u plz send me the code what you wrote in u r mechine?
Thanks…
martin can u plz post the code what you wrote in u r mechine?
Thanks…
I have a simplified solution - a form with one field (StringEdit, edt InvoiceId), lookup method uses a hard-coded account:
public void lookup(){ element.testLookup(this, “2202”); }
And the testLooupMethod() is your method just with the range fixed:
public void testLookup(FormControl _ctrl, CustInvoiceAccount _account)
    Query   query;
    qbr     = qbds.addRange(fieldnum(CustInvoiceJour,InvoiceAccount));
    qbr.value(queryvalue(_account));
    lookup  =   SysTableLookup::newParameters(tablenum(CustInvoiceJour), _ctrl, true);
now my code is this,
public static void LookupInvoiceIdbyCustAccount(FormControl _callingControl,InvoiceId _invoiceId)
Query query;
//lookup.addLookupfield(fieldnum(CUstInvoiceJour,InvoiceAccount),true);
and in the InvoiceId form control of datasource i called this method as follows
// super(_formControl, _filterStr);
plz check it.
Thankyou…
