Hi
I am trying to comment the base code of creation of number sequence for prodid in prodtablecreate form .wen i comment the code number sequence generation got stopped but other fields like item id all got disabled …how to enable the fields
Thanks & Regards
Manjusha.D
What changes have you made?
Having a topic titles “hi” will severely reduce your chances of having people believe you are asking a real question and therefore they will not open the message. Edit your original post to have a meaningful title.
What actually you are trying to do…
As per my understading of the problem…
You dont want to generate the number sequence for prodid ?
1.Prodid number shouldnt be system generated number or you want to create the prodid manually…
If this is the case no need to commet the code…
Naresh Kolli
