Bank leger entry is applicable for all the Bank transaction, if it is done through the bank master (not directly in the GL account).Similarly, Check ledger entry is applicable only if you are using automatic check printing functionality.
For every check printing, a ledger entry will be posted into check ledger entry table. Likewise for check cancellation. If you are not using autoamtic check printing facility, then this ledger will not be affected.
Thanks 4 d quick reply… But as all the cheques r using in bank a/c ledger entry also. then y should we use check ledger entry seperately for reconcilation… what is the need in it…
