Hi All
How do we Disable the delete permission from the tool Bar(delete button or F4)
is there any can help me…
try it with permissions, so create a new role where you modify the rights so that a user can’t delete a record.
set DELETE ALLOWED propery to no in the form or table you want to disable…(if for all users, otherwise follow permissions)
That’s indeed the solution when you want to modify an object.
Jan has the best solution here. The correct method is to assign appropriate permissions to your users.
