HF30SP4_003 - Inventory transactions are maybe not upgraded after SP4 install, Hot Fix Corrections made for: When upgrading to 3.0 sp4 the following two jobs are executed: updateInventTransIdReferenceLot updateInventTransIdReturn The upgrade jobs could in some situations be ignored if the line containing ttsabort is executed. If a problem uccur, the jobs has to be run after the upgrade. The jobs are provided in this HotFix. Affected Objects: updateInventTransIdReferenceLot updateInventTransIdReturn
