morning i was start nav getting mentioned error please help me any one .
Either the caller does not have the required permission or the specified path is read-only"
regards
raghunathreddy
8861556243
regards
raghunathreddy
8861556243
Well if you want help, then it would be helpful to know a bit more.
Like exactly what are you trying to do and which version of Dynamics NAV is this about??
Hi Erik,
thank you for your reply.
i am using Nav 2013 version .when i was start Microsoft dynamic nav 2013 its showing above mentioned error .
Regards
raghu
Hi raghu
In order to get the complete access please following below steps :
Go to Service folder in the Server for 2013 it is
C:\Program Files\Microsoft Dynamics NAV\70
Right click on the Service Folder and go to properties of the folder.
Go to Security Tab of the Properties
Click Edit in the Security Tab
Check the users under the “Group or user names” section.
If not available click add button and add the relevant users.
If users are already existing then check the permission of the users.
After assigning the permission to users click Ok.
Try restarting and you will be good to go.
please suggest me how to resolve below mentioned error.
i am using Microsoft dynamic NAV 2013 using when i was start NAV getting below mentioned error.
“Either the caller does not have the required permission or the specified path is read-only”
regards
raghu
Hi Harikiran,
Thanks for your reply.
I tried above what above u mentioned steps but still showing same issue. Please could u suggest is there any other alternative way.
Please can u share your skype id:
Regards
raghu
ok.
hari.kiran50
Error seems to be very clear I belief, just try giving all sort of necessary Permissions. Do check the path you have the right to Read and write as well if you are performing a write operation.
Check this link
community.dynamics.com/…/either-the-caller-does-not-have-the-required-permission-or-the-specified-path-is-read-only-microsoft-dynamics-nav
Right click on the Microsoft Dynamics NAV and go to properties of the folder.
Add Everyone, check full control and modify.
Click apply and Ok button.
Restart the service from Microsoft Dynamics NAV Administration
You’re just giving Everyone FULL CONTROL over everything in your NAV folders! I’m sure it will fix your permission error, but that’s surely not a solution for a production environment. Just saying!
