Help translating SQL Query to Dynamics AX2012 AX
Hi everybody,
Sorry if this seems s…d, I’m a newbie to AX2012.
Need your help translating this SQL Server query to AX, can’t get it right on AX. If I add the group by clause it stops working.
Original SQL Server query
select LASTUPDDATEPHYSICAL, AVAILPHYSICAL, INVENTSUM.ITEMID from inventSum
INNER join inventDim
ON inventSum.InventDimId = InventDim.inventDimId
INNER join inventJournaltrans
ON inventJournaltrans.ItemId = inventSum.ItemId
INNER join inventTable
ON inventTable.ItemId = inventSum.ItemId
AND inventTable.dataAreaId = inventSum.dataAreaId
INNER join inventItemgroupitem
ON inventItemgroupitem.ItemId = inventTable.ItemId
AND inventTable.dataAreaId = inventItemgroupitem.ItemDataAreaId
ON inventItemgroupitem.ItemGroupId = inventItemgroup.ItemGroupId
AND inventItemgroupitem.ItemGroupDataAreaId = inventItemgroup.dataAreaId
AND inventSum.AvailPhysical > 0
AND inventItemgroup.gstItemGroupType = ‘RAW’
group by inventsum.ITEMID, LASTUPDDATEPHYSICAL, AVAILPHYSICAL
AX2012 Query (Not working)
while select ItemId,LastUpdDatePhysical,AvailPhysical from inventSum
group by inventsum.ItemId, inventSum.LastUpdDatePhysical, inventSum.AvailPhysical
join inventDim
where inventSum.InventDimId == InventDim.inventDimId
where inventJournaltrans.ItemId == inventSum.ItemId
join inventTable
where inventTable.ItemId == inventSum.ItemId
&& inventTable.dataAreaId == inventSum.dataAreaId
where inventItemgroupitem.ItemId == inventTable.ItemId
&& inventTable.dataAreaId == inventItemgroupitem.ItemDataAreaId
where inventItemgroupitem.ItemGroupId == inventItemgroup.ItemGroupId
&& inventItemgroupitem.ItemGroupDataAreaId == inventItemgroup.dataAreaId
&& inventSum.AvailPhysical > 0
&& inventItemgroup.gstItemGroupType == ‘RAW’
Thanks in advanced for your urgent help
To explain a bit more
When i add the group by clause, no records are return by the query, if I remove the group by, it returns all records just filterd by these
about 4000 records,
When I run the query in SQL SERVER it returns 200 records, those are the records I need for my report.
Do I have to add group by to each table joined??? Can you please show me the correct sintax?
So far I’m stuck.
you have not selected inventDimId from inventsum table so you need to change 1st two columns
while select ItemId,LastUpdDatePhysical,AvailPhysical,InventdimId from inventSum
group by inventsum.ItemId, inventSum.LastUpdDatePhysical, inventSum.AvailPhysical,inventSum.inventDimId
let us know whether you are getting desired result with this changes or not…
Hi Krishna
I’ve created a job to test my DP class, but even with the modifications you suggested, the query still does not return any records, please see attach image.
Thanks in advanced for your help
You should remove inventSum.AvailPhysical in your group by clause, I don’t understand why you want to group by a qty
Please verify solution if it solves your problem
regards,
Thomas
The screenshot looks as expected. If you think it’s wrong, you have wrong expectations.
If you group a query, you get values only for fields that you group by or that are aggregated (e.g. using sum() function). Because you don’t group by nor aggregate any RecId field, they are all empty. Their values are simply not defined. It’s exactly the same both queries (SQL and X++), because ultimately X++ uses SQL too.
Your current query returns four fields only: ItemId, LastUpdDatePhysical, AvailPhysical and InventDimId. You shouldn’t expect any other value.
Yes Martin,
I understand, this is my new attemp but still no success.
while select ItemId,LastUpdDatePhysical,AvailPhysical,InventDimId from inventSum
group by ItemId, LastUpdDatePhysical, AvailPhysical, InventDimId
join wMSLocationId, inventDimId from inventDim
group by wMSLocationId, inventDimId
join gstAgingDate,ItemId from inventJournaltrans
group by gstAgingDate, ItemId
join BOMUnitId,ItemId,dataAreaId from inventTable
group by BOMUnitId, ItemId, dataAreaId
join ItemId,dataAreaId from inventItemgroupitem
group by ItemId, dataAreaId
join ItemGroupId,gstItemGroupType,dataAreaId from inventItemgroup
group by ItemGroupId, gstItemGroupType, dataAreaId
Hello Verci,
I tried your original query, and it works for me if I omit the gstItemGroupType condition. So I think there is an issue at that point.
static void Job2(Args _args)
InventSum inventSum;
InventDim inventDim;
InventItemGroup inventItemGroup;
InventItemGroupItem inventItemGroupItem;
InventTable inventTable;
InventJournalTrans inventJournalTrans;
join inventDim
join inventTable
//&& inventItemgroup.gstItemGroupType == ‘RAW’
info(“found it”);
You might also try putting the && inventSum.AvailPhysical > 0 up near the selection of inventSum, after the group by, but I don’t really think that should make a difference.
The same question is also being discussed in the duplicate thread on another forum.
