Help! - Quickest way to rename fields
A client has requested a name change for a number of fields in Navision, what’s the quickest solution? Cheers! Mike
Hi Mike, if your client is using Attain you could use Navision Attain Translation Tool. However, it still depends on the numbers of fields your customer want to have changed. I would not use NATT for changing only the customer name field (and in all related tables). Could you be more specific, please. Regards Walter
Hi Walter, The field names that require changing are:- vendor = supplier and item = product. Thanks for your help Regards Mike
Hi Mike, The quickest way to do this is to create a form based on the virtual table Field and do a simple replace (Ctrl + H). Regards, Reijer.
