Help opens a blank page
Fl does not open the help in dev
Could you please provide a meaningful description of your problem and an appropriate title?
We can’t help you if you don’t explain your problem.
Trying to open the help using shortcut key F1 In the development environement . When I press F1 a blank page is opening.
AX 2009 SP1.
Do you have the help files installed?
technet.microsoft.com/…/hh314109(v=ax.50).aspx
www.microsoft.com/…/details.aspx
Title changed from “Dynamics AX 2009” to “Help opens a blank page”.
The help files are installed.
Help files are installed. Checked with them twice.
The error is
Addresee: Kerndoc://functions/char2num
Sys documentation --functions-- char 2num…
I have tried it with different solutions, Anybodys help appreciated.
