Hi All
I have problem in workflow.that problem is explained with screen shot(How i designed workflow in configuration wizard)
So please if you are free see the document and solve my problem.
3377.worflow.docx (314 KB)
i don’t know how to explain it that’s why i follow in this way
please help me
Have you setup workflow correctly, go to Basic/Setup/Workflow configuration and validate that your services are working correctly.
Another thing, so are you testing this with different users, that would be good to do. Are you getting the alerts for approving the workflow?
Hi Fabricio,
thanks for giving replay.I validated the URL the below error comes.please help me
Client found response content type of ‘text/html; charset=utf-8’, but expected ‘text/xml’.
The request failed with the error message:
This means your url contains a sharepoint site. Please install the workflow web application in the Default Website and set the Default Website port to 85 and adjust the URL in AX accordingly and try to validate again.
