help me online user
static void sendMsgToOnlineUsers(Args _args)
Eventmsgbox msgbox;
EventmsgboxId msgboxId;
SysClientclientsessions1 clientsessions1;
while select clientsessions1
where clientsessions1.Status == clientsessions1tate::Running
msgboxId = Eventmsgbox::nextEventId();
msgbox.initValue();
msgbox.ShowPopup = NoYes::Yes;
msgbox.Subject = “Message aler”;
msgbox.Message = “Message testing from ax application”;
msgbox.SendEmail = false;
msgbox.UserId = clientsessions1.userId;
msgbox.msgboxId = msgboxId;
msgbox.AlertCreatedDateTime = DateTimeUtil::getSystemDateTime();
msgbox.insert();
error is
Variable Eventmsgbox has not been declared.
plz help me
v v reddy
send message alert to online users in axapta
Hi Veera,
You have declared Eventmsgbox as msgbox and in the while loop , why are u using Eventmsgbox::newEvent…use msgbox instead of Eventmsgbox in the loop…
Thanks and Regards,
Kevin
THANK U
THANK U
Eventmsgbox :: msgbox
EventmsgboxId :: msgboxId
msgbox.initValue();
msgbox.insert();
BUT ANOTHER ERROR SYNTAX MISSING
Hello verra,
what is EventMsgBOX?
Is this a table or class or etc…?
Ramya
TABLE
I AM SENDING THE MESSAGE FOR ONLINE USERS
ITS POSSIBLE HELP
hello,
I think there’s a problem with your table EventMsgBox, replace with you EventInBox, you can try the following code, it work on Dynamics AX 2009:
Eventinbox msgbox;
EventinboxId msgboxId;
SysClientSessions clientsessions1;
while select clientsessions1 where clientsessions1.Status == sessionstate::Running
msgboxId = Eventinbox::nextEventId();
msgbox.initValue();
msgbox.Subject = “Message d’alerte”;
msgbox.Message = “Message de test de l’application AX2009”;
msgbox.InboxId = msgboxId;
msgbox.insert();
regards,
The code you mentioned is wrong because of following reasons -
  • there is no standard AX object as ‘Eventmsgbox’.
  • From AX 4.0 onwards, ‘sending message to users’ functionality has been replaced with alerts.
Sending alerts was discussed many times in this forum with code example. Please search for them.
Is it possible to send a message to offline user also.
darshana
