HELP.. :( [ Get row index and compare field value ]
hi guys,
Does anyone here can help me on how I could get this result on my report or could tell me if it is possible to get this kind of result.
This is the record of the EMPLOYEE 1 in the table.
And below is the required output I need in the report.
The user wants to see only the records from May 1 - 31, 2011.
VESSEL
POSITION
START DATE
END DATE
VESSEL 1
Cook
May 1 2011
May 3 2011
VESSEL 1
Cook
May 4 2011
May 6 2011
VESSEL 1
Cook
May 8 2011
May 10 2011
VESSEL 1
HELPER
May 11 2011
May 15 2011
VESSEL 2
Cook
May 16 2011
May 31 2011
VESSEL 2
Cook
June 1 2011
June 15 2011
Im thinking if I could call the row index or id and compare a certain value of its field on the next row,
Example: To merge the all the record in vessel 1 and cook position, the start date of the next row should be plus one on the enddate of the previous row. If not, then it would not merge and should be printed on the report… is it possible guys?
I hope I had explained it clear.
I NEED THIS RESULT IN MY REPORT: (below)
VESSEL
POSITION
START DATE
END DATE
VESSEL 1
Cook
May 1 2011
May 6 2011
VESSEL 1
Cook
May 8 2011
May 10 2011
VESSEL 1
HELPER
May 11 2011
May 15 2011
VESSEL 2
Cook
May 16 2011
May 31 2011
In this result the first and second row has been merge since it has same vessel and position, while the 3 row lapsed 1 day from row 2 so it shouldn’t merge to the first 2 rows, then on the fourth row, it has same vessel but different in position and the fifth row is different in vessel, while the sixth row is not cover in the range of time needed by the user.
Thanks in advance.
Miss Blue
