Help file creation.
Can any one help me to create Help files in ax 2012 or ax 2009
hi,
it might help you,
http://dynamicsuser.net/forums/t/38691.aspx
http://dynamicsuser.net/forums/t/46641.aspx
Hi Satya,
For AX2009, when you install by default you would get help server so i can say that wont take much of your effort. contrary in ax 2012, probably you would work little more.
Because in AX 2012 while installation you need to check the help server checkbox, for whcih you should have IIS installed ,sharepoint & Search server. So basically this installtaion will create website in IIS and that website would get inserted in ax tables (Help table).
