hello ,
can it be done by permmisions ?
i have some users that i want onlt to disable them the delete button
not to delete an item etc.
thanks in advance
hello ,
thanks in advance
Hi Asher,
what particular table or module are you referring? You could check user right access and check the privileges at System Administrator–> Common → User the edit Role
Yes, permissions are intended exactly for these things, nevertheless the configuration is different in AX2012 and in older versions. If you need further help, don’t forget to mention your version of AX.
Hello brenda and martin ,
yes it was permissions, i gave the user view only and it was good for me ,
i’m working with ax 2009
