Good Morning.
I have been searching everywhere and can not find any good examples or documentation on how to use this web service,
I urgently need help please.
Could you maybe post a code example of how it works and or point me to a good sample project or something please.
Also when I add the reference to c# it generates the reference code incorrectly e.g Namespace.TestApp.Service1 generates as Namespace.TestApp.Namespace.TestApp.Service1, This I can fix so its just a bonus question.
I don’t have any example on hand specific to HcmWorker, but if you have a specific question, I might be able to help.
Regarding your other question, the system works correctly - you should name the reference Service1, not Namespace.TestApp,.Service1, to the result you expect.
Thanks for your reply, I am not calling it that I name it AIFHcmService but in the generated code behind the service it makes it
Namespace.TestApp.Namespace.TestApp.AIFHcmService
Instead of
No Clue why it is doing this but I just rename the lot and it works. I just have absolutely no clue how to insert update and delete information using the HcmWorker Webservice that is why I was looking for a sample.
Thank you for your time.
If you’re talking about HcmWorkerImportService, it does not support deletion (according to Standard Document Services).
If you want a simple example of using a document services, look at Creating sales orders via AIF in AX2012.
Thank you this helped! I have one more question though. I am trying to do an update but I need an entity key can you point me in a direction that might help me better understand the entity key?
An entity key uniquely identifies a document. It may be composed from more than one field and it’s usually generated from the primary key of the root data source. HcmWorker is the same case - it’s primary key is SurrogateKey, i.e. RecId, therefore the entity key has a single field: RecId.
If you want to see the code, walk through the following example in the debugger:
HcmWorker worker = ...;
AifEntityKey entityKey = new AxdHcmWorkerImport().createEntityKey(worker);
