I everyone, I need to create a second database for testing. Can somebody tell me how to create it and set it up to have access to it. I created the database but I don’t see it when I try to open the databse from the client. Thanks,
The server cannot handle two databases at the same time. You need to set up a second server. If You do it on the same maching You need to edit the services file on the server and on Your clients because this second server needs to run on a different IP-port. You’ll find all the information You need about this in the installation manual (chapter 1.6 in w1w1ism.pdf)
