Hi, From your experience, could I get from any of you the ideal “Hardware Specifications” for 35 users 5 Companies Navision 3.60 (SQL) POS - Retail Module Approx 6000 Entries a day Does Navision have any “Official Hardware Specs” ? I am not sure about this. Any info on this would be interesting. Cheers
Hi Rohit, You can check it in w1w1ism.pdf or w1w1adg.pdf file.
Hi Rohit, There are no clear specifications from Navision’s side and when they mention something, the other possibilities/combinations aren’t discussed. I remember very recently there was a v.good discussion in a forum here on this issue, do perform a search. Regards
There exists a document: System requiremnts for Navision Attain 3.60 Michael
Hi. Your NTR should have a sizing guide that was produced by Navision and Siemens for version 2.60 some years ago, but it still holds. //Lars
