hard core the invoice date in the form
first of all i am using ax 2012 r3 I have a question when ever i am creating a sales order and then click on invoice then a form come up for where we select the qty as packing slip or invoice and there is a tab called set up there we have a field called invoice date as default it is showing as today date according the time zome.
I want to write a logic to change the invoice date based on business requirement so where should i write the code so that every time we click on invoice the date should be changed according to the condition and gets invoiced later .
I know we can change the date by while invoicing by calling the
salesFormLetter = SalesFormLetter::construct(DocumentStatus::Invoice); // Get a new instance of SalesFormletter
salesFormLetter.transDate(SystemDateGet()); // Set the invoicedate
salesFormLetter.update(salesTable, // SalesTable
SalesUpdate::All, // Quantity to update (SpecQty)
AccountOrder::None, // AccountOrder
false, // Proforma only?
true); // Printout?
but in my case the user will do invoicing manually put the date should be changed automiatically…
any help guys???
The date gets initialized here,
\Classes\SalesFormletterParmDataInvoice\createParmTable
by calling this.parmTransDate(), it by defaults sets the systemDate, but you can overwrite it based on a valid business requirement.
