Hi there,
My client is using Nav 4.0.2.22611 with SQL2005SP1.
I’m encountering a problem in only 1 dataport. This dataport exports the content of only 1 data item. On the OnAfterExportRecord I update the current record, concerning exportinformation, like some timestamps and booleans and I close with MODIFY; Nothing happens. My exportinformation is not being updated in any way. The debugger doesn’t show anything unussual, just passes the MODIFY statement. I moved this part of code to dfferent places in the dataport but nothing happens.
This is very strange, because in my testing environment (same specs) I don’t have this problem. My instinct tells me this is related to SQL. At the moment we are encountering some problems with security (sync problems to be exact), but that shudn’t result in this behavour.
Let me know if you have any direction I can look into, cause I’m out off options…
Thanx.
