I need an advice. I have a client where the requirement is such a way that the business is classified in three catagories.
It has four division.Divisions are further divided into two sub groups.
how to group this in Navision.
Regards
Narayan
admin1
#2
Hi Narayan,
I would suggest you to use dimensions.
Hi ERIC,
I have used dimension for another classification
DaveT
#4
Hi Narayan,
This a difficult one to answer without knowing the details - e.g. what is the reporting requirement, common customer base etc
Have a look at responsibility centers - this will group but you may have some development to do around filtering views of the data.
admin1
#5
Yes, but you can just add more dimensions.
jsrark
#6
What do you need to analyse?
I believe that in the standard system you can run with upto 8 Dimensions.
One option is to use a name convention on the DIMENSION to give groupings.
For example A-AA for Division A unit AA, then A-BB for unit B then B-AA for Division B (but with more user friendly name).
We use dimensions for Division, Cost Centre, Sales Category, Product Line, Product Class and Project.
We use Analysis Views to provide a pivot on the data by any combination of those dimensions.
