hi…
can NAV do the grouping using Variable?
i set the condition in my report, and it works
i put the condition result in 1 variable…
can i group it?
thanks
hi…
can i group it?
thanks
You can try by coding…
refer this post for ex:
Hi stan,
Did you ever find a solution to your problem? If you did, would you mind sharing it with us and if any of the posted answers helped you on the way, then please verify them.
Thank you.
