i have grouptotal field on item no and location code.
but it is not appeared correctly.
suppose:
barcode--------------------LOCATION----------quantity
100101-1-------------------OUTLET-------------1
100101-1-------------------CACHECABAT-----1
My report show only:
Report output will be following because it’s group based on barcode and location code:
help me.
OBJECT Report 50017 Adjustments
OBJECT-PROPERTIES
Date=18.01.12;
Time=14:48:15;
Modified=Yes;
Version List=Monir;
PROPERTIES
OnPreReport=BEGIN
//IF PrintToExcel THEN
// MakeExcelInfo;
END;
OnPostReport=BEGIN
// CreateExcelbook;
END;
DATAITEMS
{ PROPERTIES
DataItemTable=Table32;
DataItemTableView=SORTING(Item No.)
ORDER(Ascending)
WHERE(Item No.=FILTER(1…));
OnPreDataItem=BEGIN
IF( Barcode<>’’) THEN BEGIN
// Item.SETRANGE(Item.“No.”, Barcode) ;
“Item Ledger Entry”.SETRANGE(“Item Ledger Entry”.“Item No.”, Barcode);
END;
IF( DocumentNo<>’’) THEN BEGIN
“Item Ledger Entry”.SETRANGE(“Item Ledger Entry”.“Document No.”,DocumentNo) ;
END;
IF( Warehouse<>’’) THEN BEGIN
“Item Ledger Entry”.SETFILTER(“Item Ledger Entry”.“Location Code”, ‘=%1’, Warehouse) ;
// “Item Ledger Entry”.SETRANGE(“Item Ledger Entry”.“Location Code”, Warehouse) ;
END;
IF(( PositiveValue=TRUE) AND ( NegativeValue=FALSE)) THEN BEGIN
“Item Ledger Entry”.SETFILTER(“Entry Type”, ‘=%1’,“Item Ledger Entry”.“Entry Type”::“Positive Adjmt.”);
END;
IF (( PositiveValue=FALSE)AND ( NegativeValue=TRUE)) THEN BEGIN
“Item Ledger Entry”.SETFILTER(“Entry Type”, ‘=%1’,“Item Ledger Entry”.“Entry Type”::“Negative Adjmt.”);
END;
IF (( PositiveValue=TRUE)AND ( NegativeValue=TRUE)) THEN BEGIN
“Item Ledger Entry”.SETFILTER(“Entry Type”, ‘=%1|=%2’,“Item Ledger Entry”.“Entry Type”::“Positive Adjmt.”,
END;
IF (( PositiveValue=FALSE)AND ( NegativeValue=FALSE)) THEN BEGIN
END;
// IF (“Negative Adjmt.” =TRUE) THEN BEGIN
// END;
“Item Ledger Entry”.SETCURRENTKEY(“Item Ledger Entry”.“Item No.”);
“Item Ledger Entry”.ASCENDING(TRUE) ;
//window.OPEN(’@1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@’,intProgress);
// timProgress := TIME;
Number := “Item Ledger Entry”.COUNT;
END;
OnAfterGetRecord=BEGIN
// ItemBarcode:=“Item Ledger Entry”.“Item No.”;
CLEAR( CurrentBarcode);
CLEAR( CurrentLocationCode);
CurrentBarcode:= “Item Ledger Entry”.“Item No.” ;
CurrentLocationCode:=“Item Ledger Entry”.“Location Code”;
END;
OnPostDataItem=BEGIN
// window.CLOSE;
END;
GroupTotalFields=Item No.,Location Code;
SECTIONS
{ PROPERTIES
SectionType=Header;
SectionWidth=23250;
SectionHeight=846;
CONTROLS
{ 1000000010;Label ;2100 ;0 ;2550 ;423 ;HorzAlign=Left;
CaptionML=ENU=Negative/Positive }
{ 1000000011;Label ;6300 ;0 ;2100 ;423 ;HorzAlign=Left;
CaptionML=ENU=Barcode }
{ 1000000013;Label ;11400;0 ;1950 ;423 ;HorzAlign=Left;
CaptionML=ENU=Warehouse }
{ 1000000014;Label ;15150;0 ;1800 ;423 ;HorzAlign=Left;
CaptionML=ENU=Cost }
{ PROPERTIES
SectionType=GroupFooter;
SectionWidth=23250;
SectionHeight=423;
OnPreSection=BEGIN
CurrReport.SHOWOUTPUT:=(PositiveValue=TRUE);
END;
CONTROLS
{ 1000000000;Label ;0 ;0 ;1500 ;423 ;HorzAlign=Left;
CaptionML=ENU=Pos. }
{ 1000000001;TextBox;1800 ;0 ;3150 ;423 ;HorzAlign=Left;
SourceExpr=+TotalPositiveQty }
{ 1000000002;TextBox;5850 ;0 ;3900 ;423 ;HorzAlign=Left;
SourceExpr=“Item Ledger Entry”.“Item No.” }
{ 1000000003;TextBox;11100;0 ;2700 ;423 ;HorzAlign=Left;
SourceExpr=“Item Ledger Entry”.“Location Code” }
{ 1000000005;TextBox;14550;0 ;3750 ;423 ;HorzAlign=Left;
SourceExpr=Unitcost }
{ PROPERTIES
SectionWidth=23250;
SectionHeight=846;
OnPreSection=BEGIN
CurrReport.SHOWOUTPUT:=(NegativeValue=TRUE);
END;
CONTROLS
{ 1000000007;Label ;0 ;0 ;1500 ;423 ;HorzAlign=Left;
CaptionML=ENU=Neg. }
{ 1000000008;TextBox;1800 ;0 ;3150 ;423 ;HorzAlign=Left;
SourceExpr=+TotalNegativeQty }
{ 1000000016;TextBox;5700 ;0 ;4050 ;423 ;HorzAlign=Left;
{ 1000000017;TextBox;11100;0 ;2700 ;423 ;HorzAlign=Left;
{ 1000000018;TextBox;14550;0 ;3750 ;423 ;HorzAlign=Left;
{ PROPERTIES
DataItemIndent=1;
DataItemTable=Table2000000026;
DataItemTableView=SORTING(Number)
ORDER(Ascending)
WHERE(Number=CONST(1));
DataItemVarName=;
OnPreDataItem=BEGIN
IF (PositiveValue =TRUE) THEN BEGIN
PositiveItemLedger.RESET;
PositiveItemLedger.SETRANGE( PositiveItemLedger.“Item No.”, “Item Ledger Entry”.“Item No.”);
PositiveItemLedger.SETRANGE( PositiveItemLedger.“Document No.”,DocumentNo) ;
END;
PositiveItemLedger.SETFILTER( PositiveItemLedger.“Location Code”, ‘=%1’, Warehouse) ;
END ELSE BEGIN
PositiveItemLedger.SETFILTER( PositiveItemLedger.“Location Code”, ‘=%1’, “Item Ledger Entry”.“Location Code”) ;
END;
IF( PositiveValue=TRUE) THEN BEGIN
PositiveItemLedger.SETFILTER(“Entry Type”, ‘=%1’, PositiveItemLedger.“Entry Type”::“Positive Adjmt.”);
END;
PositiveItemLedger.SETCURRENTKEY( PositiveItemLedger.“Item No.”);
PositiveItemLedger.ASCENDING(TRUE) ;
“Value Entry”.SETRANGE(“Value Entry”.“Item No.”,“Item Ledger Entry”.“Item No.”);
“Value Entry”.SETFILTER( “Value Entry”.“Location Code”, ‘=%1’, Warehouse) ;
END ELSE BEGIN
“Value Entry”.SETFILTER(“Value Entry”.“Location Code”, ‘=%1’, “Item Ledger Entry”.“Location Code”) ;
END;
END ELSE BEGIN
CurrReport.BREAK;
END;
END;
// IF (Positive =TRUE) THEN BEGIN
